Freesker OBD2 Diagnose Tool
  • Ich habe tatsächlich mehrfach versucht, die monierten Meldungen zu löschen - absolut ohne Reaktion! Hatte vermutet, dass es an meinem störrischen Ocean liegt (Lars weiß worüber ich spreche...) aber offenbar geht es nicht nur mir so. Das Spurhaltesystem funktioniert ohnehin nicht und wird auch als permanenter Fehler im Bildschirm angezeigt - Freesker hat mehrfach von mir alle Fehlermeldungen erhalten, um zuletzt festzustellen, dass sie das Problem nicht lösen können. Vielleicht klappt es ja nach dem ersten Scheitern dann doch noch mit OV Loop?
    Hi again,
    Freesker is neither comparable to OV Loop nor to any other solution. As clearly communicated, the current error messages should not be taken into account. As explained above, they are part of a protective mechanism and do not indicate that Freesker is unable to perform the required functions. Simply put, this behavior is a safeguard designed to protect you and your vehicle.
    To reiterate: Freesker has significantly advanced the overall Fisker development and diagnostic landscape. For this reason, it should also be in your interest to continue protecting Freesker — especially against parties who are so called Fisker Assocations and attempt to replicate them 1:1.
    Finally, if you have any suggestions for improvement or features you would like to see, we are always open to feedback. Only by working together can we continue to grow and improve.
    Best regards,
    Freesker Team
  • Hi there,
    Lane Keep functionality is, among other factors, controlled by the FCM. Typical issues can include a missing calibration or missing / incorrectly written VIN or SecOC data. Beyond these points, no additional common issues are known for the FCM, meaning that the existing Freesker functions are fully capable of resolving such cases.
    Of course, hardware defects are something we cannot address through software. In those situations, replacement of the ECU is required. However, even in this case, Freesker provides the necessary functionality to commission and bring a new ECU into operation.
    Best regards,
    Freesker Team
  • Weder mit dem Freesker Tool noch über OV Loop konnte der Spurhalteassistent bei meinem Ocean zur Funktion gebracht werden. Offenbar schaffen es beide nicht, die Fehlfunktion über die Software zu erkennen und zu lokalisieren. Sollten es tatsächlich Hardware-Probleme sein, würde ich immerhin erwarten, dass die Diagnose dieses Resultat auch so ausgibt. Für mich verwirrend ist zudem die Aussage von OV Loop, dass das Problem vermutlich nur mit dem FAST-Tool gelöst werden kann - ist FAST nicht letztlich auch "nur" eine Software, oder kann mit FAST auch Hardware repariert werden?
    Ich bin sehr dankbar, dass wir als Ocean-Gemeinde mittlerweile auf zwei Hilfswerkzeuge zurückgreifen können, mit denen schon viele Probleme gelöst werden konnten - von Seiten der IP-Inhaber ist aber noch viel Luft nach oben.
  • Bei einem der ForenMitglieder ist das wohl schon von OVLoop gefixt worden. Ich finde nur den Beitrag nicht mehr. Es sind wohl mehrere , die aktuell das Problem haben. Brinier war es das Update von 2.2.3 auf 2.5.
  • Hat jemand eine Idee was bei mir falsch läuft?
    Ich habe neu auch Freesker Pro, aber leider ist die Seite leer (weiss)
    Habe meinen VLinker Dongle angeschlossen und per Bluetooth verbunden. Mit meinem Androit Tablet mit Edge auf dem EU Webserver auf verbinden geklickt. Der Dongle wird gesucht und gefunden, ok ich bestätige, danach habe ich nur eine weisse Seite, das ist alles.
    Vlinker habe ich die Firmware aktualisiert, leider kein Erfolg, Auch mit Chrom oder Opera kein Erfolg
    Danke für eure Tipps
  • Hast du auch das durchgeführt?
    Und hast du den richtigen Dongle ?
    FD + ist wichtig
    vLinker FD+
  • Das ist nur für Chrom, für Edge benötigt es die Änderung nicht.
    Ja ist ein vLinker FD+
    Der Dongje darf nicht mit dem Bluetooth des Handys gekoppelt werden
    Sondern erst durch die App.
