OV Loop update 2.2.3
  • Bei mir geht auch nach allen möglichen Resets einiges nicht:
    Kein 4G, damit auch kein Internet, kein neues Profil möglich, Zeit ist immer noch falsch.
    Das ist die Antwort vom OVLoop-Support:
    Please note that if you do not see the 4g icon, that you may still have an active connection to data. In order to double check this connectivity, please check that your navigation screen is updating with current geolocation data or try to open an app like Spotify. Also please be ensure that your wifi pairing is not on, because the vehicle is not able to actively search for a wifi and data connection simultaneously.
    Did you pair to your OLoop account before receiving the 2.2.3 update. If so please see the instructions below to repair your OLoop account to regain functionality.
    First you must delete your OLoop paired account if present.
    1. Turn on your car with your key fob
    2. Close the driver door
    3. Tap the profile icon at the top left or right of the central screen to access car's profile setting
    4. Tap + at the top right in the profile settings
    5. Accept the Terms and click "Continue"
    6. A QR code will generated from your car
    7. Scan that QR code from the O Loop App to pair.
    For your time issue, this appears to be a known issue with DST synchronization on EU-spec Oceans. It has existed since before Fisker’s bankruptcy and was never formally addressed at the firmware level. At this time, there is no confirmed manual fix available.
    The center display’s time is synchronized by the TBOX, which relies primarily on the cellular network’s NITZ time signal or GPS. Assuming the cellular network is broadcasting the correct time (which is normally the case, otherwise mobile phones would also display the wrong time), the issue is likely that the TBOX is either failing to correctly parse the Daylight Saving Time flag or is prioritizing stale internal time data that has not yet refreshed.
    Because we do not have access to deeper diagnostic data from Fisker, we cannot provide a definitive root cause. In many cases, the TBOX will eventually re-calibrate and revert to the correct time on its own. If the issue persists, performing a hard TBOX reset may force a resync with the current network data.
    Schön beschrieben, aber es funktioniert nicht, ebensowenig wie die App von denen. Falscher SoC und das Auto steht immer zu Hause, egal wo ich bin. Selbst wenn das Auto im Heimnetz ist, funktioniert die App wahrscheinlich nur bei Vollmond.
    Zum Glück kann ich den Kram monatlich kündigen.
  • Ja, mehrfach mit Sicherungen ziehen, jetzt mit Schalter, aber auch mit Freesker Pro.
    Keine positive Veränderungen.
    Dummerweise habe ich bis 2.5 bezahlt.
    Das Auto ist jetzt nicht mehr im Heimnetz und jetzt bin ich mal gespannt, was die Jungs unternehmen.
    Bei mir mit 2.5 geht das Heimnetz und 4G ohne Probleme, sollte also nicht am 2.5 liegen. Heimnetz SSID und Passwort ohne Sonderzeichen
