Hi allerseits.
Majd hat heute Nacht eine Beschreibung der Abkürzungen der Steuergerätebezeichnungen auf Discord gepostet.
Ich denke, die Volltextbezeichnungen könnten von allgemeinem Interesse sein.
Falls das in einem anderen Forumsbereich besser aufgehoben ist, gern von den Admins verschieben:
[AGS] Active Grille Shutter
[ADB] Adaptive Driving Beam
[ADAS] Advanced Driver Assist System
[ACU] Airbag Control Unit
[ACP] Airconditioning Control Panel
[AMP] Amplifier
[AP_FL] Anti-Pinch Front Left
[AP_FR] Anti-Pinch Front Right
[AP_RL] Anti-Pinch Rear Left
[AP_RR] Anti-Pinch Rear Right
[AL] Atmosphere Lamp
[BCS] Battery HV Current Sensor
[BMS] Battery Management System
[BMU] Battery Management Unit
[BCM] Body Control Module
[CDS] Center Display Screen
[CCU] Charging Control Unit
[CIM] Column Integrated Module
[CVM] Coolant Valve Module
[CFM] Cooling Fan Module
[CMRR_FL] Corner Mid Range Radar Front Left
[CMRR_FR] Corner Mid Range Radar Front Right
[CMRR_RL] Corner Mid Range Radar Rear Left
[CMRR_RR] Corner Mid Range Radar Rear Right
[DVRC] Digital Video Recorder Camera
[DC-CHM] Direct Current Charge Machine
[DMC] Driver Monitor Camera
[DSMC] Driver Seat Memory Controller
[DWSG] Driver Window Switch Group
[EPS] Electric Power Steering
[EAS] Electrical Air Compressor System
[ECC] Electrical Climate Controller
[EDR] Event Data Recorder
[EWP_B] Electrical Water Pump Battery
[EWP_FD] Electrical Water Pump Front Drive
[EWP_H] Electrical Water Pump Heat
[EWP_RD] Electrical Water Pump Rear Drive
[EWM] Electrical Wiper Motor
[EXV_B] Electronic Expansion Value Battery
[EXV_HP] Electronic Expansion Valve HPC
[ESP] Electronic Stability Program
[FDHA_FL] Flush Door Handle Actuator Front Left
[FDHA_FR] Flush Door Handle Actuator Front Right
[FDHA_RL] Flush Door Handle Actuator Rear Left
[FDHA_RR] Flush Door Handle Actuator Rear Right
[Lumber] Four-Way Lumber
[FBM_L] Front Beam Module Left
[FBM_R] Front Beam Module Right
[FCM] Front Camera Module
[GW] Gateway
[HUD] Head-Up Display
[IDS] Instrument Display Screen
[ICC] Integrated Cockpit Controller
[IBS] Intelligent Battery Sensor
[iBooster] Intelligent Booster
[KS] Kick Sensor
[LSC] Left Side Camera
[MRR] Mid Range Rada
r[MCU_F] Motor Control Unit Front
[MCU_R] Motor Control Unit Rear
[MDV] Motorized Deco-Vent
[MFS] Multifunction Steering
[MIS] Multimedia Interactive Switch
[MPC] Multipurpose Camera
[OMC] Occupant Monitor Camera
[OHC] Overhead Console
[PAS] Parking Assistant System
[PCU] Parking Control Unit
[PMS] Particulate Matter Sensor
[PSM] Passenger Seat Module
[PEPS] Passive Entry And Passive Start
[PKC] Phone Key Controller
[PKC_ANT_L] Phone Key Controller Antenna Left
[PKC_ANT_R] Phone Key Controller Antenna Right
[PWC_L] Phone Wireless Charging Left
[PWC_R] Phone Wireless Charging Right
[PVIU] Photovoltaic Integration Unit
[PASC] Power Adjust Steering Column
[PDU] Power Distribution Unit
[PLGM] Power Lift Gate Module
[RLS] Rain Light Sensor
[RAC] Rear Airconditioning Control
[RVC] Rear View Camera
[RSC] Right Side Camera
[RCM] Roof Control Module
[RSM] Roof Shade Module
[SCM] Suspension Control Module
[TBOX] Telematics Box
[TPMS] Tire Pressure Monitoring System
[TDS] Touch Display Screen
[TRM] Trailer Module
[USB Box] USB Box
[VCU] Vehicle Control Unit
[VSP] Vehicle Sound For Pedestrians
[WTC_B] Water Thermal Controller Battery
[WTC_H] Water Thermal Controller Heat
